Bill Bowden
It's an old (1960s AM radio) air dielectric, planetary drive with ball
bearing 6X reduction). It's a very small mechanical cap measuring
about 9/8 inch square by 11/16 height with closely spaced plates
(150pF and 100pF). Problem is, the oscillator section jumps about 5KHz
out of 1Mhz or maybe 0.5% with small adjustments to the cap. It
appears it may be losing a ground connection (or high resistance) to
the moving plates, or possibly some dust between the plates. I assume
the ground connection is made through the ball bearings. I tried
spraying some contact cleaner on the ends of the shaft but it didn't
help. What would you suggest to restore the capacitor to it's original
condition? I thought about soaking it in alcohol, but maybe that's not
a good idea.
-Bill
a good idea.
-Bill
