ChairmanOfTheBored
My guess is they're not plugged in at the wall, and it's a staged
photo.
That was my first response, except I didn't use the term "wall".
photo.
Nah, it's in Germany. Haven't them yer-a-peein's been subject to
imperial rule for centuries? I'm guessing they have mandatory GFCIs,
such that their rulers can speechify about "giving" people "safety"
and "security".
In Heaven, the British run the police, the French do the cooking, the
Germans do the repairs, the Swiss run the trains, and the Italians are
the lovers.
In Hell, the Germans run the police, the British do the cooking, the
French do the repairs, the Italians run the trains, and the Swiss are the
lovers.
On Sat, 12 Jan 2008 16:46:05 GMT, "Rich Grise, Plainclothes Hippie"
And in either, you're still the idiot!
Yes, but it also requires that the body be IN the PATH, not some lame
imaginary field lines.
This is called a PATH. Of course even a dope like you
knows that
current flows THROUGH paths, from a source to its return (or attractor),
so of course there would be some of that current flowing through a body
within the PATH.
A couple mA actually.
Sorry, but you are thinking about it incorrectly. There isn't any
unique "the path". When there is an electric dipole in a uniformly
conductive medium (such as water), an electric field is established
that can be represented by directional lines perpendicular to
equipotential lines. Current will flow along those directional lines
in proportion to the electric field gradient there. Insertion of
something more conductive at any point will distort the field so as to
concentrate current through the more conductive area.
That's true for someone who has a normal heart, and who is not
electrically susceptible due to a catheter or some other intrusion
that would concentrate the current. In any case, a couple of mA is
quite easily reached when there is very little resistance, such as the
100 ohms or so when a body is immersed in water.
Take a copper cube with two attachments on opposite faces that are less
than one tenth the size of the cube. Place a silver rod that is one
tenth the cube face width in diameter over in the corner of the cube,
between the two nodes. Pass current... I'd say that the silver rod
never sees any of it.
The two guys in the pool represent even less percentage than the rod,
AND the two nodes are NOT across the face of the pool, and the bottom of
the pool, they are across two nodes of a fucking power strip. 90% of
that pool's body of water sees ZERO current.
Even if both contacts have equal area and are centered in the pool,
there will be nowhere in the pool that actually has zero current.
Theirs is not a center tapped setup at all. Both sides are HOT if Iam
not mistaken. Still, there is no path from one node to its return node
that passes THROUGH the folks in the pool.
photo.
Mark
Rich said:"Raises" the question. "Beg the question" is a special term - see def.
9:
http://dictionary.reference.com/browse/beg the question
Ok, ok, I lived in too many places. That confuses the tongue a bit.
After a while you are fluent in many languages but none of them 100%
"poifect".
But, quote: "beg the question, to assume the truth of the very point
raised in a question."
I believe that definition hits it on the nail. My impression is that VLC
doesn't really do what FlashPlayer is supposed to do. For example this
morning someone in Europe had spooled that movie to MP4. VLC took it,
showed the first (still) image. Then after finishing the download, poof,
all gone. Downloaded it again to file, this time it worked.
come to think of it... does european 220 volt have an earthed neutral,
or is it like US 220, but without the earthed neutral that gives us
110?
Get mplayer. Works great even on downloaded Flash movies ripped from
Firefox's cache.
z said:come to think of it... does european 220 volt have an earthed neutral,
110?
Thanks. Lots of download sites. Do you know which one would be safe?
Western Europe nowadays has 230 volts, with one neutral conductor, connected
to earth, and one live conductor, carrying 230 volts AC.
The pool situation could be extremely dangerous, even if the plastic
insulation is perfect -- the whole setup acts as a giant capacitor, with
roughly the following capacity:
mu0 x mur x A 8.9E-12 x 3.8 x 15
C = ------------- = ------------------ ~= 0.5uF
d 1E-3
(with A in square meters, d in meters, and mur the relative mu of PVC)
This capacitor creates the necessary path to ground. At 50Hz and 115 volts
(the resulting AC voltage with a 230 wire and a neutral wire under water),
this capacitor would allow for an AC current of well over 10mA, a lot of
which will flow through the body if positioned between the conductors and
the pool floor. Although this is not considered immediately lethal, it will
cause spasms and loss of muscle control, most probably resulting in
drowning of the victim. Anyone getting within a meter or so from the wires
would start feeling anything from slight tingling to severe discomfort.
I'd recommend only foolish people do as shown in the picture, so as to
improve the general level of intelligence of the human population.
Richard Rasker
