How is battery capacity calculated ?
To all the electronics gurus on this newsgroup -
how is battery capacity decided - for example
if I buy a 6 Volt 5AH sealed lead acid battery,
how did the manufacturer come up with the number
5AH ?
Phil Allison
5AH ?
** You could easily Google that question you know.
FYI:
For SLA batteries, makers use the "20 hour rate" for the published AH
figure.
So for 5AH, the battery is discharged at 250mA for 20 hours for a final
terminal voltage not less than 1.7V per cell.
http://www.steveduncan.net/assets/images/mfg_curves.jpg
..... Phil
Artem
Who is the manufacturer? Some manufacturers provide discharge/charge curves. Bear in mind that the lead-acid batteries rapidly degrade at 100% charge / discharge cycle.
