Ray
I have built a regulator to control battery charging using 4 IRF2804
mosfets, driven with a 555 timer, and it works ok, Charging is between 10
and 70 amps, depending on which generator I drive the charger with.
but trying to connect #12 wire to the small leads on the mosfets which are
mounted to a heatsink was a problem. I destroyed a couple by tearing off
the leads when trying to route the big copper wire. Also hard to solder big
wires so close together...
Thanks for any ideas
