FIO . . . .
assuming pin #1 is the one closest to the power plug
Viewing the CA5668 with its labeled side being readable, there is a divot within the case just above the units assigned pin # 1.
Now, back to your situation of having your current metering knob setting to a lower ma range.
No damage was inflicted o your meter, due to your having a low resistance of the meters very low resistance 10A current shunt in circuit, because you had already plugged into the 10 A receptacle.
With your metering info, it is suggestive of the voltage regulator working if you earlier read ~11.54 Vdc at the power input connecto and then being on down to ~9VDC at the pin 11 power input of the LA4127 audio power output IC.
Seemingly the audio output IC is not wanting to pull and consume any power . . .OR . . . your reading of the instant current capabiliy of the AC adapter is actually being correct.. . . . adapter isht KAPUT ?
Seems logical to prove that now:
First, find your . . .perceived . . . freshest / "hottest " of your AAA thru D dry cell cell options and plug in meter leads for 10A DC current range and set selector knob to 10 A this time.
Then do that lightning quick test of your selected cell . . . or, sequentially, test multiple cells . . . now, a HOT cell will read from 5-6 amps just for that instant test.
As for finding a cell testing at 1 amp . . . shucks,I wouldn't even use that one in a battery powered clock.
The point is now, that if you can find cells testing up to that HOT current capability in cells being tested, your meter being used in 10 amps testing, is OK.
So that AC adapter is not putting out anywhere near the power being needed.
For even further testing, round up 6 hot cells to totally power up the unit with batteries and that should let us then see if the LA4127 is operative or not.
