I'm looking for sensors to build an IMU. Classical IMU use 3
accelerometers and 3 gyros. For accelermeters we can find cheap sensor
(Freescale MMA7260Q 5$ for 3 axis). The gyros are more expensive (AD
ADXRS300 30$ per axis).
Do you know if we can measure the angle rate using using two
accelerometers separated by a small distance d (2 cm) ?
Can you point me to some articles that explain how we can do that.
I made some computations starting from the navigation equation and I
found that the difference between the two accelerometers outputs A1 and
A2 is directly :
A1-A3= W*W* d + 2*W*Phi*d
Where W = the earth rotation angle rate
Phi is the angle rate of accelerometer1 with respect to accelerometer2.
if A1 et A2 are at rest , Phi =0 and we can measure W.
I'm not sur that of my computation and I need help to relate A1-A2 to
the angle rate (W+Phi) given directly by a gyro.
Thanks.
A2 is directly :
Thanks.
