Stupid spammers.....
Platforms
Content
Provided that you discharge the cap correctly, with a discharging resistor tool, NOT a screwdriver, using correct procedure, then once discharged, short out the terminals, the cap will be safe to handle.those massive caps can zap you long after the machine has been unplugged
Visited Jamaica at a friends house who's neighbour across the back lane had a few roosters. I figured out how to silence him for brief spells. Play back his recording on an iPad just before he starts to crow. just for laffs.PVR (Personal Voice Recorder)
This was originally bought as a mono-channel recorder for transcribing 'music' pieces from my then PC-speaker output.
Years later, we acquired an African-Grey parrot named "Wonk" by my then teen daughter.
I hauled out the non-used PVR and extended the record/playback contacts to 2 large PTM push-button switches just outside his cage.
These were at first 2 long-lever limit switches inside the bars, which got twisted and munched by "The Beak".
Wonk quickly learned (maybe by random choice) to record and play back his screeches, mumbles and occasional phrases.
I used to be Test Engineering Mgr at the Burroughs/Sperry/Memorex/Unisys Peripherals plant in Winnipeg starting '83 where we refurbished those old 14" drives. Some of the baseplates worked well for a Hibachi BBQ The 207 model had a 1 HP+ (?) linear motor that was the fastest servo at its time with high tech embedded servo.Back in the 70's and 80's
Hello,
Some time ago I came accross "the maldivian arc welder":
