> Mike Monett wrote:
>> Getting an amplifier with flicker noise that low near DC is
>> pretty good. Any chance to post a schematic?
>> Thanks,
>> Mike Monett
> That was several years ago. I probably still have it kicking
> around in a drawer in my lab.
> It used iirc 3x Toyo-Rohm low noise transistors (2SD786) in
> parallel.
> The 1/f corner was around 1 Hz or a bit below (good BJTs are
> amazing).
> Cheers,
> Phil Hobbs
Heh, I'm having problems finding a datasheet in Engish. There's some
tantalizing fragments, such as
en = 0.55nV / sqrt(Hz) (at 10Hz, 10mA)
http://doc.chipfind.ru/pdf/rohm/2sd786.pdf
There's also some discussions of the low noise at:
http://sci.tech-archive.net/Archive/sci.electronics.design/2005-
12/msg02183.html
12/msg02317.html
There's probably more but I didn't take time to check.
The 2SD786 seems to be available for $26.98, but there's no date so
it's not clear if that price is still valid:
http://littlediode.com/components/2SD786_Transistor.html
The Analog Devices MAT02 and SSM-2210 are less expensive at about
$6.00/1k:
http://www.analog.com/en/other/matched-
transistors/MAT02/products/product.html
The Mat02 and SSM-2210 are also supposed to have a fairly low corner
frequency, depending on the collector current. But it doesn't look
to be as low as 1Hz for the 2SD786:
http://www.analog.com/static/imported-files/data_sheets/MAT02.pdf
http://www.analog.com/static/imported-files/data_sheets/SSM2210.pdf
The SSM-2210 datasheet describes three devices in parallel, giving
500pV/SQRT(Hz) and a corner of 1.5Hz. It uses a red LED as abias
current reference voltage. This is also described in the Analog
Devices app note AN-102:
http://www.elektronik.ropla.eu/pdf/stock/adi/temp/pdf/2611.pdf
So it would be very interesting to take a peek at your
implementation if you have time to post it.
Thanks,
Mike Monett
I've seen the Analog devices circuit reproduced in lots of places.
You might notice that it uses the LED and transistor Vbe voltage
reference trick mentioned by Walt Jung in an earlier post.
George Herold
