The EQ section alone on a Neve V series (and derivatives) has 18 op-amp
stages.
Can't find a schematic for that one, but I'm looking at the schematic of a
Neve 83022EQ which seems to be representative.
http://www.danalexanderaudio.com/neveinfo/83049/83022EQ.jpg
There are a ton of op amps, but they aren't all cascaded on the signal path.
For example, 16 op amps are in 4 state-variable filters each composed of 4
stages, plus a helper amplifier.
In actual use, the full bandwidth and amplitude of the output signal of the
equalizer rarely if ever flows through all 16 op amps.
The state variable filters are typically used as hi pass, lo pass, shelving,
peaking or nulling filters, so only a fraction of the audio band is affected
by each. When each parametric section's boost/cut control is centered as it
often is, very little of the output signal passes through them.
There are 5 op amps with gain either -1 or +1, cascaded across the top of
the schematic. They are always in the signal path of the eq. They each pass
the entire audio band. However, it looks like it may be possible for the
whole eq to be bypassed.
My analog parametric eqs include individual bypass switches for each
section, and a bypass the whole eq. I can see maybe 20 ops amps actually
interposed full-band and full-signal in a record/play signal path, but 100
seems like a reach.
I've done experiements where we built up a string of 20 unity and 10 dB
stages, using fairly primitive op amps like TL074s. No reliable detection
in level-matched, bias-controlled tests, using very clean sources, very
clean monitors, and a variety of listeners who were either audio engineers
and/or audiophiles, and thought they would hear a difference.
