Hello, I purchased a replacement adaptor for a musical keyboard of mine. There are two millimeters of the actual adapter exposed as shiny metal when the adaptor with tip is inserted(it is slightly longer than the insertion hole.)
I was also thinking of covering the last .5 cm with black electric tape. Are there any problems with this idea? Would just the 2mm metal outside of the housing be an electrical problem in any way - or is the current in the tip/inside part, and is safe?
Thank you,
Joshua
Edit: The tape is more or less to make it look nicer too.
Thank you,
Joshua
