Yes , exactly.
Edit, in post 11 it would be the bottom picture
Martin
Martin
What reading would you expect to see if the resistor was shorted?Absolutely, of course. Also tell if the resistor was shorted or open circuit. Likewise if the LED was working or not.
Martin
Ok, I understand the short has continuity, but a good reading also has continuity and low ohms. So how do you tell when it is a short just using a dmm. Sorry if I am confused0;00 or up to 0.03. Remember that a short is electrically connected. Like a direct link.
Martin
Both are short circuit. A direct link. Think of putting the probes together. Albeit, the probe leads will have some resistance in the wire.Ok, I understand the short has continuity, but a good reading also has continuity and low ohms. So how do you tell when it is a short just using a dmm. Sorry if I am confused
Ok, I see what you are saying. Thank you very much.Both are short circuit. A direct link. Think of putting the probes together. Albeit, the probe leads will have some resistance in the wire.
I think the best way to explain is a short is not wanted. A component that should not read such a low resistance and has failed. Components can fail short circuit or open circuit.
Think about your resistor, take it out and replace with a solid wire link. Now you have 0 Ohms, a short or continuity. YOU know that is not right. It should read the resistor value.
Martin
If the resistance is a LOT less than expected, then suspect a short or (in your case) misplaced probes.Ok, I understand the short has continuity, but a good reading also has continuity and low ohms. So how do you tell when it is a short just using a dmm. Sorry if I am confused
Martin, I think your explanation was just fine. What we have here with @stspringer is a demonstration of the GIGO principle: Garbage In, Garbage Out. And it has been going on for quite some time now with no apparent understanding on his part of what a "short circuit" is, or how it differs (if and when it does) from "continuity," or what resistance means, or what resistance to expect when measuring resistance in connecting wires and dmm probes. Or even where to position the probes to measure resistance, hence his misunderstanding of the dmm reading.Glad you might understand. I am terrible at explaining things, so sorry.
Others will likely enlighten you with better explanations.
Martin
In other words, to date @stspringer exhibits a total lack of understanding of electricity on his part. Add to this the poor pictures he posted that do not show clearly what is allegedly being "measured" with the dmm, or even what components are allegedly being measured (resistor, LED, wires?), and you have a nice recipe for continued misunderstanding and a total waste of our time. How can anyone advise him about what he is doing wrong when we cannot even see what he is doing? A real schematic diagram would help, along with better pictures that show everything. Otherwise, fuggeddabout it (an old Italian expression, partially translated here into English).
I suggest we here on EP just give it a rest and let him discover everything he "needs to know" using the time-honored smoke-test procedure, aided perhaps by his dmm if he ever learns how to use it properly. To get sufficient smoke he might need to put together a set of six series-connected D-size cells to provide nine volts (initially) with a source capacity of several amperes. That should be more than enough power to smoke most quarter-watt sized resistors of sufficiently low ohms value and/or almost any 3-mm LED.
It won't be enough power to melt the connecting wires, which would demonstrate how a real short circuit connected to real power really works. But he probably doesn't "need to know" that right now. After all, the LED-and-resistor circuit does light up the LED when appropriate power is supplied! What more can one expect (or learn) from a battery, a resistor, an LED, and a couple of jumper wires?
Oh, wait! We can confuse ourselves by making continuity and resistance measurements, using random probe positions, and then post questions about it here in the forums. Yeah, that will work.
You are making me feel like I should be afraid to ask questions on this forum because I am so ignorant of electronics. This is not a good feeling.
I was looking for helpful explanations no mater how stupid I may sound asking these questions. I liked Martins response.
don't be afraid to ask and no it isn't a good feeling
unfortunately hevans1944 can be somewhat terse at times, don't let him put you off
Yes, Martin gave you good answers
Hang in there, it will sink in with time. We all learn at a different pace
Dave
I am sorry if my criticism came across that way. Never be afraid to ask questions here. There are no stupid questions, but you may find lots of stupid answers, or answers that are just plain wrong. That is why it is important to have more than one source before forming an opinion or accepting any answers you receive from the the World Wide Web.You are making me feel like I should be afraid to ask questions on this forum because I am so ignorant of electronics. This is not a good feeling. I was looking for helpful explanations no mater how stupid I may sound asking these questions.
Erm, I think that is this thread....For example, there is some controversy in another thread about whether diodes, specifically light-emitting diodes or LEDs, have terminals identified by positive and negative polarity. They do not.
Ooops. So it is.Erm, I think that is this thread....
Martin
I couldn't agree more. Watch lots of Youtube videos too. You will soon see who knows what they are talking about and those that don't.Never be afraid to ask questions here.
@stspringer perhaps my response was a little too harsh, but from my point of view we have been working with you for weeks without seeing any progress in your understanding of electricity. I hope that EP is not your only resource for the study of electricity, because this is not a teaching forum. .
