Imaging that I have a whole pile of carriers, all running separately.
Modulate each carrier with something, say QPSK.
Now I tell you that I chose the carriers and the modulation so that the spectra of each will not interfer with the others.
Add all the modulated carrier signals together.
Actually usually prodcuded in the frequency domain and made into a tijme signal with a DFT of some sort, but the signals are the same.
Then add some subtle things that keep the peak of the signal under control and provie some sequences that make synchronisation easier and you have it.
Visualise what it looks like? A mess of lots of carriers all at the same time.
The bit rates, symbol rates on each carrier tend to be adaptive to the channel that that carrier is seeing, so good channels will be given more data, higher rates, higher constellations. Poor channels will get less data.
The narrow bandwidth of any chanel tends to mean that delays are less important: you don't have to worry so much about delay spread.
So an OFDM symbol, each carrier sees a normal constellation point. Carriers see them at different rates, so I guess an OFDM symbol is a collection of QPSK symbols distributed over a lot of different carriers.
As I mentioned, I suspect real systems likely create the signals in the frequency domain, a frame, packet at a time, so maybe the symbol is the whole packet?
Someone who actually knows about 4G might provide a better explanation, or fix some of my guesses.
