Platforms
Content
ed, I didn't use the center tap.hi ed, yes, that's the transformer I used. I will check the pcb and post back. I think the 8 ohm side went to the first ten ohm resistor, but I'll check. steve, how can I implement your suggestion?
Not sure what steve would suggest, but did you try the R3 increase as per my post #5?steve, how can I implement your suggestion?
hi alec, i'am going to change that resistor tonight and will post back. will the change increase /decrease freq?Not sure what steve would suggest, but did you try the R3 increase as per my post #5?
if you have a centre tap on the primary you can use half the primary winding which will -- all other things being equal -- halve the voltage at the output.
I'll try the resistor first as that is easier to get at. thanks guys.boy, that's a great idea steve. now I don.t know which mod to try first.
ok alec, changed r3 to 200k. the output voltage dropped dramatically, now output at test leads is 245 mv. whoopee!! the side effect however is that as steve noted the gain of the second op amp has to be increased. I think the resistor between pins 6&7 needs to be adjusted. theres a 39k there now. what value would you suggest?I'll try the resistor first as that is easier to get at. thanks guys.
hi edd, thank you for the input. actually, the u1b is running on a reg 9v. does the gain of u1b go up with a higher value resistor? I opted not to use r8,r13 and one 20k pot for zero adjust. the gain now with the r3 change just barely moves the meter pointer with the leads shorted...
Sir pete g . . . . . . .
Part 1 . . . . .
Vice that loop gain alteration of the U1A op amp oscillator circuit , a less circuit invasive and altering procedure would have been to insert a drop resistor between the osc op amps output and C2 coupling capacitor.
Initially try using 220 ohms and work your resistor value upwards until you get exactly the osc level value that you want.
Part 2 . . . . .
Short the test leads together to get maximum coupling into the U1B signal amplifier to see if a full scale meter deflection can be produced by the detected DC and having R11 or R12 to their minimum resistance position.
If not, then the U1B loop gain R8 and R13 resistors values need to be shifted to get a bit more than maximum deflection . . . . then, it being brought back down with R11- R12 adjustments.
That regulated supply reduction down to 5VDC . . .holds stable readings for a long time from that 9V supply battery.
73's de Edd
That's way above what the schematic shows. Rather than increase that value it might be easier to slap another resistor (say 1k) in parallel with R7.I think the resistor between pins 6&7 needs to be adjusted. theres a 39k there now.
hi alec, the original schematic for this esr meter had a 39k across pins 6&7.That's way above what the schematic shows. Rather than increase that value it might be easier to slap another resistor (say 1k) in parallel with R7.
I,am also using a tl062 instead of tlc272.hi alec, the original schematic for this esr meter had a 39k across pins 6&7.
hey steve, well, you're right about the freq. it went up a lot. the problem now is I can't get enuf gain out of u1b. the result is I can't zero the meter. I tried putting another 1k across r7, no change in gain.changing R3 to 200k does not directly affect the amplitude. It has the effect of changing the frequency.
you may be measuring a lower voltage for several reasons:
1) the transformer is less effective at the higher frequency
2) your measuring equipment is having problems due to the higher frequency.
3) Stray inductances and capacitances are having an effect on either the voltage or the measurement.
Another major issue is that ESR measurements are typically done at 100kHz. Whilst it's not extremely critical, doubling it is certainly not going to give you results comparable to those in datasheets out taken by others.
Sounds like a really fun and useful project. I can take that puppy to Mendelson's and try-before-I-buy some of their dirt-cheap NOS electrolytic capacitors.
hi all, b4 this thread ends, I just want to say how much I enjoyed it. thank you to all who contributed. I really learned a lot. thanks again. till next time. peteI'm suffering Mendelson's withdrawal syndrome.![]()
