Glen said:
For an 8 kW system at $45k installed, financing cost is about
$300/month and your avoided cost for a net metering hookup (you
wouldn't consider it if net metering wasn't available in your area) is
about 8 kW * 5 hours/day * 30 day/month * $.15 /KWH = $180/month saved
on your electricity bill right now if you live in sunny southern
California for example.
Net metering is a subsidy and a hideous tax on other users.
Simply stealing electricity from your neighbor makes more economic sense.
Further, a typical domestic synchronous inverter when fully and properly
amortized today requires more than 100 percent of the electricity sent
through it to pay for itself.
Proof of all this is very simple: Not one power utility anyplace
anywhere is routinely using conventional silicon pv for cost competitive
electrical generation.
The reason is that conventional silicon pv never was, is not now, and
never will be renewable or sustainable. The latest of CIGS technology
MAY get us as much as one third of the way towards renewability and
sustainability.
And those utilities with solar array research facilities will not tell
you their avoided cost equivalence because it is ludicrously noncompetitive.
Note that when a pv panel matches the utility avoided cost, you have
gained ABSOLUTELY NOTHING. All you have is an elaborate smoke and
mirrors "paint it green" use of conventional power sources.
Only when pv panels can provide energy at substantially under current
utility rates does sustainability emerge. And only on THAT FRACTION that
is below and displaces conventional sources.
The more conventional silicon pv panels that are installed, the FURTHER
in the future any possible renewability or sustainability will occur.
A reasonable estimate of the California energy subsidy is that it will
SET BACK pv renewability and sustainability by at least FIFTY YEARS.
See
http://www.tinaja.com/whtnu06.asp for February 19th for an analysis.
See
http://www.tinaja.com/glib/energfun.pdf for a tutorial.
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss:
http://www.tinaja.com/whtnu.xml email:
[email protected]
Please visit my GURU's LAIR web site at
