Hi all
I have an old mains-powered CD player where the CD doesn't work anymore, and the antenna has snapped off, so not much use for radio. (Although I could go replace the antenna, nobody uses radio anymore anyway.) This device also has an iPhone/iPod mounting point with a 30-pin connector to power and interface to the iDevice.
To breathe new life into the player, I bought a wifi-connected media device (Tronsmart M1000 EzCast) that has an audio out socket, and I wired it into the iPod plug audio input lines using the cable from a busted set of headphones. The cable feeds through a hole into the CD tray area in the top, and plugs into the audio out of the M1000. The M1000 device is small enough that I can pop it in where a CD would normally go, and close the lid. Neat!
Surprisingly, it works great. I know a little about electronics in principle, an I kind-of know about passive components, transistors and ICs, but only as idealistic building blocks. And I have next-to-no experience with real-world projects like this one. So I was surprised how well it worked.
Now the M1000 has no battery, and instead has a USB socket for power. So I have to use a USB power pack and run the 5v power line past a crack in the lid of the CD player to power the device. This is not only untidy, but it also means I need two mains power sockets to run the thing. It would also be nice to be able to use the CD player in this configuration when it's running on batteries, and hence fully portable.
So I decided to get an old USB power cable with a busted PC end plug, and do the same as for the audio - wire it into the iPod connector and feed it through a hole into the CD tray area for powering the device. This works fine to charge it (and I can charge phones this way also). But when I'm playing audio at the same time as powering the device from the CD player, the audio has lots of noise, and it's simply unusable for music. If I unplug the audio cable, the noise (and the music) stops.
Has this something to do with a "ground loop" that I've read about (but admit to knowing nothing of)? Or is it some kind of interference induced into the audio cable through the M1000 device?
Can this be cured with a capacitor at the right place or some similar elector-magic?
