I think the OP has the right numerical answer (although I'm having trouble following how he got it.) I did the simple voltage divider approach, but since it should not matter from which direction the voltage division is done, I did it both ways (Eqns 2 & 4) to ensure the answer was the same both ways. MAPLE worksheet attached.
There's my mistake. In the table of component values, where it says w = 50 rad/s, I just mentally changed that to 50 Hz, not 50 rad/second.
With that change both my solutions will get Z = 2.
I also did a mesh solution which also gets Z=2.
