Jan Panteltje
I don't think that any mass production transistor radios used class A
audio output stages -
from the late 50's onwards the push-pull
transformer coupled class B output stage was the most common, until
the transformerless designs cam in.
Seems you are right:
http://people.msoe.edu/~reyer/regency/parts_placement.jpg
In Eurpe we were a litte later, I think.
first 2 transistor, then 6.
The 2 transistor ones were cheap, and a clever design, used the transistors 2 times,
first as RF amp, and then again as LF amp...
The 6 were not push pull:
Perhaps 1 RF/Mixer, 1 osc, 2 IF, 1 audio drive, 1 audio out?
Then the number of transistors increased, and likely push pull:
http://www.vintage-technology.info/pages/history/histpamtr.htm
The early transistors had very
limited power dissipation capability and the low idle consumption of
class B suited battery power better.
At the end of the fifties or start of the sixties I build little amplifiers with Philips
OC13, OC14 ('power', OC44 (RF) and OC45 transistors.
There also was the OC16 POWER transistor.
Use in class A it really could output _watts_:
http://homepages.nildram.co.uk/~wylie/Mullard/Mullard.htm
Car radios often used class A
even in hybrid designs where the RF and early audio stages were
implemented with valves/tubes.
kevin
It is a long time ago,
OC45 with the paint scraped off was a great photo detector too.
One day I had my pre-amp on, and noise came and went...
It turned out to be clouds in front of the sun, the black paint was damaged a bit.
