John Larkin wrote:
John Larkin wrote:
Jim Thompson wrote:
03:12 -0700, John Larkin
I'm on my third laptop right now. Every time I plugged my Dell's "fat
snake" into the wall, I drew quite an arc. The Lenovo's arc was not
noticeable, but now I get a noticeable arc with my new HP -- not as
big as the Dell's, however.
I know FA about switch mode power supplies, obviously, so I wonder
1. What produces the arc?
2. Why would different power supplies produce different arcs (does it
just depend on output power capability)?
3. Why is there no arc when I pull the plug from the outlet?
Dumb switching power supplies have a bridge rectifier and a big
electrolytic filter capacitor. If you plug them in near the peak of
the AC line waveform, the charging current will spark.
Better supplies, with inrush limiters, or PFC (power factor corrected)
front-ends, have much less inrush charge.
Ask Jim for details. He is *so good* at designing switching power
supplies.
Indeed I am >
I like the ucc28019a. works like a champ. Undervoltage lockout too
Cheers
So does the L6561. But poorly documented and no model; and ST ignores
my pounding on their door >
If I could make major changes I'd design ST out _forever_!
Might be the new normal. I want to design in a National video driver,
LMH6722. Has a thermal pad under its belly. In the datasheet they forgot
to mention where its s'posed to be connected to. Probably V- but I'd
rather make sure. Filed a support ticket with the new owner TI on 10/2.
Got a service request number.
Today is 10/8 and (finally! ... or so I thought) there was a message in
the inbox this morning. A form letter, merely saying that, tada, a
service request number has been issued. New number: Same as the old number.
So I responded politely as to when I might be expecting an answer. No
response all day.
Hurumph!
Get one and ohm it out.
No kidding, that may be the only way :-(
Just made a CAD model for a 100-TQFP processor. Now I know why I chose
to become an analog guy and not a digital one.
Do you mean a PCB decal, or an actual Autocad sort of thing?
PADS makes IC decals really fast, for sort of standard things with
rows of numbered pins.
Are you doing 3D Solidworks sort of physical modeling? It is fun to
finally spin that stuff around in space, or take a virtual walk under
the IC pins.
No, just the schematic library part and footprint. A hundred pins, most
of which have names like this:
(OC0A/OC1C/PCINT7)PB7
One typo and all hell can break loose because the routing resources in
those uCs are sparse and can be unforgiving. Just had a major
re-shuffling in one of them on another project, not because of an error
but for a feature change. When those get maxed out in port pins the
design can slow down as much as Van Ness at rush hour, mainly because of
routing compromises.
You *should* be able to either grab the names from a spreadsheet or
cut-n-paste from a datasheet. The vendors often have models already built
that can be used for a starting place, too.
Only for some CAD packages, if at all. My CAD has a lot of the Atmels,
just not this big one.
which one?
... OTOH, our CAD people demand that
chips look on the schematic like they do on the board - no functional
partitioning (except BGAs, for some reason).
I insist on the same, I really hate netlist-style schematics where the
front axle is on page 17 which the left front wheel it on page 32.
Exceptions are logic gate and opamp multi-packs, of course. And I never
use large BGAs, those can spell doom in a hi-rel environment.
isn't reliabily and BGAs something that was perfected many years ago?
Sure, at least in the larger packages. Joerg is living in the '80s. They
even worked well then but many didn't have the process down.
for something like a big FPGA I think it it makes sense to put core
power, jtag
configuration and such on one symbol and each bank on a separate
symbol
Agree 100%. Even "small" 144-pin QFPs are a mess when they're shown as one
big box on a page with wires everywhere. Joerg probably doesn't like busses,
either (someone here objected to them a while back).
Actually I do like buses a lot. Especially the ones with comfy seats and
WiFi on board
... Just kidding, I do like buses on schematics.
Busses where the contents are not similarly named (not Bus[0:11], rather
BusWr, BusRd, BusEn,...)?
