Richard
I bought a cheap flourescent luminair. Works of 12 VDC 500mA.
I took it apart because I thought the lamp inside is about the right size
for a project. Ballast is electronic on a small PCB, only a few descrete
components. Obviously the ballast is cheap to make.
Inside is an unbranded T5 lamp of 8W. It's 288mm long so it is a mini TL
lamp. Two pins on each end.
Looking at Philips technical site I see that the recommended ballast for
this kind of Philips lamp/lamp would be type BPL 02W. This ballast is a
simple inductor. It's compactish, 85mm x 39mm x 28mm. Wiring is standard
when using a choke and a starter.
But, the electronic ballast in this luminaire does not employ the heaters.
Pins at both end are joined together.
I suppose that whether employing the cheap electronic ballast or the choke,
the lamp gives the same light output. True? But for economy, I guess one
would always go with the proprietry electronic ballast. Although mains
working would require a step doen transformer. So, cost savings would
not materilise - perhaps.
Not sure about any differences in lamp protection and safety.
I just get to wondering when I come across this kind of thing why anyone
would select the choke ballast.
