1) Having the greens shorted out across a bank of 10 when no ematches are put in, how will this effect battery life? Seems it would be really bad on it?
Not great on battery life but I didn't think it was an issue since you are using a large SLA battery and I assumed you only connect power when you are getting ready to go. If power consciousness is on the plate too the design may require some tweaking
you're looking at about 30mA per device. That 1K resistors (R2, R4, R8) limit the current in various paths. (10mA if no ematch in circuit)
I measure about 23mA through Q3 when not firing and 10mA when no ematch is present. I was able to reduce that to 14mA and 7mA respectively by changing R8 to 5k.
2) it doesn't matter whether you place the resistor in series with the anode or cathode. It just has to be in series. You could swap it over if you wanted to.
Roger that.
3) the 1K resistors could dissipate up to 0.144 Watts. You should pick a larger SMD resistor that is rated for higher power. R2, R4, and R8 are affected. One easy option is to get twice as many 500 ohm resistors and place them in series since each will dissipate half as much heat.
I actually calculate it higher than that. My bad, I am sorry and a bit embarrassed for that rookie mistake. The series 500ohm solution is not the best way to go for space savings. If you have to double power handling in a surface mount chip resistor what you want to do is double the value and stack the second on top of the first 2k||2k = 1k @2x power rating. But there are other options. So if all the values remain the same you could get away with changing R4 to a 1206 package of which can handle up to 1/3W.
(I wonder if R1 and R8 couldn't be a higher value? 10K anyone?)
I don't think that will work. The limiting factor in trimming in on final values is the LED. Changing the resistors around to limit currents puts me up against the limits with the LED model I am using. So if you have a part number on that LED it would be most helpful. Without it I can give some suggestions but it may require tweaking. This is a good time for a breadboard and a multi pack of leaded resistors from radioshack.
Here is what I think will work.
(1) Change R2 to 2k 0603 (reduces ready current to ~5mA 50mW
(2) Change R8 to 5k 0603 (reduces current through Q3)
(3) Change R4 to 1.5k 0805 or stacked 3k 0603 (reduces current through R4 8mA 96mW)
But again I emphasize this is really a dial in process that requires knowing more info about the specific LED's used.
1) per channel (300ma), or per full blown unit of 10 (30ma)?
All of my calcs are per channel so multiply by 10 for the whole unit. What you are referencing was 30mA/ch 300mA total but that is old info with the mods above.
3) I will see what I can find for R4 and R8,
R2, will be a 1/4W right on the green Led Anode .
Not anymore see previous comments.
Roger that.
