So, now that I successfully built a distortion pedal circuit, with the help of people here, I decided to try something else.
You will recall that I initially started with the attached schematic. Along the way, we made the following adjustments:
The voltage divider circuit was substituted with an alternate one.
I used a 4558D op amp, which is a dual amp, which is different from the single op amp identified in this schematic (so, we made some pin mapping adjustments, and buffered the second amp).
I finally received the 081 op amp called for in the attached schematic. I thus decided to try to build this circuit, exactly as shown in the schematic (now that I have the same op amp)
I built it with the op amp, the voltage divider and the diodes (according to the attached schematic) (I only installed the 500K pot so far).
I tested the circuit out and it doesn't work.
I measured my Pins in volts, and got the following readings:
1. 8.02 V
2. this number kept moving erratically, making it impossible to get a reading
3. 4.28 V
4. 0 V
5. 1.08 V
6. .494 V. Yes, that's decimal 4 9 4
7. 9.4 V
8. 8.58 V
These readings seem way off to me. As mentioned, I used the TL081CP op amp. What am I doing wrong. This should be much more straight forward than the dual op amps thing.
Thank-you
1. 8.02 V
3. 4.28 V
4. 0 V
5. 1.08 V
7. 9.4 V
8. 8.58 V
Thank-you
