73's de Edd >>> " I need Q8 transistor removed from the board, using that same 3 solder ball technique and rapidly walking the soldering iron tiplet between the 3 balls until Q8 leads reach solder release time.
Then the unit needs DC voltage monitoring of a connected CN107 to its mate at the pins 12 and 13, powering up for ONLY the time that is required for a voltage to show up on the meter . . . then power down. "
Ok,
Q8 is history now, and next I'm going to reassemble the
Main board (after I clean out those 3 holes) , and hook up everything, then turn on the
POWER, the
110 V, and let's see what the reading at
pin 12 and
13 is going to be.
Aye, aye captain, your wish is my command!
Question (just so I can be in picture ):
What is the reason we removed
transistor Q8 from the circuit, and trying to test the unit without
Q8 being in circuit at pin 12 and 13?
