Thank you Mr. 73's de Edd for your help. So here is today's report
" You might do a power down test and see if that diode (#13) is shorted, otherwise I think that they have made a mod on / for this ones +24VDC supply port source ."
I did test Diode #13 in the Power Down scenario , in diode testing mode on the DMM.
"I have two phantom board views of that small, dual portion power supply that we are looking, but they are totally displaying as black and white, with no intermediate shades of gray, for definition, so I can't find any landmark parts of that circuitry to tell you where to look for it."
I took some new pictures, hopefully they will be more clear, if not let me know the area, and I'll do my best.
"I will say that, this circuitry should be built as a parts island , within an internal portion of the MAIN A board.
I think that at one time I saw its all important main Q9 switching transistor which should be in the casing profile of the Q2 and Q4 power transistors which you can see in the #35 photo just above.
Then I lost view and that location of that transistor on the phantom photo."
I think you are talking about this area.
I noticed there are two " Q9 " transistors, one on the MAIN board (green), and one on the other board (yellow). I mark their locations on the photo.
"Then, being tied to Q9 emitter, will be the magical electrolytic, C50 . . . a 22 ufd at 63VDC rating . . . . of which its negative lead will be your metering ground referencing and the + lead will be the DDD supply source input which we had been looking for.
Give us that DC voltage level, that we are deriving our power from, for the 5VDC Dee supply."
And here is the cherry on the cake. The left side Q9 also has Q4 next to it, and Q8 (although this is not on the drawing; however, nearby I found a 22uF 100V Capacitor (not a 22uF 63V, but I guess it is the cap we are looking for). Also nearby I found a 1000uF 6.3V capacitor.
Here is that DC voltage accross the 22uF 100VDC (22uF 63V) capacitor, with AC POWER ON.
198 mV
" In a no AC power connected condition, test to see if either of your D18 switching or D20 6.2 V Zener diodes have failed, by the testing of their junctions, with your meter being placed in its diode test mode with meter leads swapped in polarity to make a two part test.( BUT 227mV does suggest a non shorted D20 and a good . . .non shorted junction on D18. ) "
I tested D20; However I couldn't find D18, maybe you wanted to say a different number diode.
"If we have supply voltage from DDD and those diodes test good, and Q9 is conducting / creating pulses from its Collector to Emitter..."
What is the procedure for checking that Q9 (on the Main green board)? to see if it's conducting or creating pulses?I'm not really sure how to do that.
Last thing that I checked was the 22uF 100V Capacitor with my DMM's capacitor's testing mode (AC was Powered Down). DMM read 22uF. I also tested the 1000uF 6.3V capacitor DMM read OL. All the testing was done in circuit.
Is it really that simple that the 1000uF 6.3V cap is in the Open state?
198 mV
