No. I have to say here, this is absolute nonsense. I cant believe I am
actually reading this.
Believe it!-)
The concept of transconductance is completely independent of whether or
not there is any control current.
Granted, but what you said you wanted to talk about wasn't the concept
of transconductance, it was that the "actual physics" of a BJT made it
a transconductance device. That being the case, what's nonsensical is
that almost anything can be called a transconductance device, so just
calling a BJT a transconductance device doesn't really say anything
about the physics behind it. Consider a simple potentiometer on the
bridge of a ship which is used to control the ship's speed. Is what's
being used to turn the screw a transconductance device? Sure. Does
it tell us anything about what's between the pot and the screw? No.
Same thing with a BJT. But dig a little deeper and we find that all
the voltage across the base-emitter diode is doing is pumping charge
through the diode, that _current_ being what causes the collector
current to flow.
Sorry, mate, this is only *your* personal concept of a "true
transconductance" device. Somewhere you have picked up an erroneous view
without even thinking about it. The *only* requirement for a
transconductance is the output current is a direct function of a control
voltage. Any current at the control terminal is simply irrelevant.
If that's true, then a BJT isn't a transconductance device because the
collector current isn't a _direct_ consequence of the base-emitter
voltage, it's once removed since the _direct_ consequence of the
base-emitter voltage is the base-emitter current.
No it don't. This is getting daft. The bipolar transistor is, to first
order, a voltage controlled current source. It is therefore a
transconductance device. Period.
See above.
Yes.
That's what I am claiming, you are claiming otherwise.
No, it isn't.
What I'm claiming is that when there is no charge being injected into
the base region, the NPN sandwich is as clearly delineated as
bread-ham-bread would be. BUT, (and it's a BIG but) when charge
starts being injected into the base region the ham starts to look more
and more like bread as more and more charged is pumped into it, with
the eventual result being that the ham looks and acts enough like
bread to take on the characteristics of bread. So, if the P type
material in the base gets enough electrons pumped into it to make it
look like N type material, then the battery connected from the
collector to the emitter will start seeing less and less resistance as
the base current gets larger and larger and will cause the collector
current to increase as the base-to-emitter voltage (and the base
current)increases.
Therefore you are claiming by this that it *is* a slab of resistance.
Yes, but only when there's enough charge flowing through the base to
allow collector current to flow. Otherwise it's more like a couple of
series-opposed diodes. See above.
It is, if we neglect rbb'.
Well, yes, everything takes on a different meaning if we start
selectively neglecting that which makes our argument untenable.
The fact that a source has to supply current is irrelevant.
And yet in your last post it was:
...."this base current is simply a nuisance."
Maybe in your next post it'll be: "Base current doesn't exist." ?-)
