We have success! A bit qualified, perhaps in-as-much-as the contact tabs cleaned off down to the copper. I didn't manage to leave the nicke
If you have a hot air gun, it'd be ideal to heat up the insulation at the end and then you could scrape the plastic off with a flat blade (not too sharp)knife.
Maybe a hair dryer could work but much harder to pinpoint the heat and get the right temperature. It could make the insulation come off like a messy mozzarella cheese. Perhaps a metal heat shield over all but the end you want to get off?
You sound resourceful. I'm sure you'll do brilliant. As they say on your side of the pond.
Hello Tha fios agabh - I do have a hot air gun - I used to use it to re-flow the MoBo around the CPU of my Acer 9300. But think the 858D (as dismantled by Dave Jones in one of his famous YouTube Videos) would have been better. But you're right about the mozzarella cheese syndrome and since the ribbon size is of paramount importance I bethought me to tread more carefully and scrape it off. Well, that did work and now I can start getting the AVR back up and working. But first . . . where's that VAUXR gone??
l plating on - but . . . I have 'buzzed' it through from the CX4 connector on the Front board to the CX4 connector on the HDMI_B'D - both test points were on the solder terminals of each of the 40 ways. Next job is to add Power, see if it turns on and stays on, then inject tones into VAUXL & VAUXR - and see how far they both get. Keep you posted
Michael 14:36 GMT
