Now 2 1/2 hours later and the AVR is temporarily re-assembled, turned ON (working OK) and the +8V. Tails have been tested. A propos the ewxtra 'Tails' I thought 73's de Edd was proposing - I now do NOT think this was so, but had some other context which is escaping me, but to do (I think) with 'Isolating'. (I hope Edd will correct me on this!)
Now. With the AVR turned on, the voltages at three salient points:
CN13A pin 7 (+4.59) CP5 pin 11 (+4.59) and CN101 pin 1 (+10.756V. with slight fluctuations)
So there we have it. I am inclined to agree that IC106 in +8V. rail is suspect. This could be a result of the surge when the connector CX102 in the SMPS_B'D soldering broke away causing quite disturbing arcing? These six IC's on the REGULATOR_B'D have easily accessible contacts. According to the specifications I downloaded from JRC, pin 1 is IN, pin 2 is GND, pin 3 is OUT. If I take Voltage readings from all six IC's it may give some indication as to their state?
IC 108 is a 4pin 2388 Low Dropout Voltage Regulator. IN = +12.43V OUT = +8.957V
IC 103 is a 3pin 7805A Positive Voltage Regulator. IN = + 10.29V OUT = +5.1V.
IC 104 " " 7905A Negative " " IN = - 0.00V OUT = -4.998V
IC 105 " " 7805A Positive " " IN = + 4.6V. OUT = +1.56V
IC 107 " " 7908A Negative " " IN = - 3.55V OUT = -11.39V.
IC 106 " " 7808A Positive " " IN = +10.8V OUT = +4.6V
So that Table is the result of the above readings from the three salient points.
And here is the Link to download the Denon Service Manual I am usin:
Denon AVR-1912 | Electrical Connector | Insulator (Electricity) - Scribd
Michael UK 20:56GMT
