Michael can you measure the voltage at Tr_Thermal? I suspect it's being pulled high by one of the following;
Q403 (FL), Q427 (C), Q451 (SR), Q463 (SBL)
Each transistor has a resistor on their collector that could be pulled to isolate where the voltage is coming from.
For example, R412 could be pulled to eliminate the possibility that voltage isn't from Q104 for the FL circuit. Make note of voltage change before and after.
Eventually, you should find what is throwing the Tr_Thermal fault (Thermal B)
