John Larkin
I'm surprised that you don't seem to know this, but if you have a
signal with sharp edges then, at each transition, a multiplicity of
harmonics will be generated and radiated into space.
Look at it like this:
. _________________________
.FIN ___| |____________________
. _ _
.NFIN____| |_______________________| |_________________
where FIN is the input signal and NFIN represents the spectral
products generated by FIN's transitions, i.e. noise, if you have no
use for the harmonics.
Now, if that signal is delayed by sending it through a gate:
FIN>---| >--->DFIN
we'll have:
. _ _
.NFIN ___| |_______________________| |_________________
on the input to the gate, and:
.DFIN _______| |____________________
. _ _
.NDFIN________| |_______________________| |_________________
on the output of the gate.
Notice that there are now twice as many noise pulses as there were
before, since there's one on each of the incident as well as the
delayed transitions.
The chain in your circuit: (View in Courier)
N1
+------------------------A
| N2 Y---CLK
FIN>--+-A / +--B
Y---A /N3 |
B Y---A |
| B B--+
| | Y \
| | | N4
GND>----+------+------+
(assuming equal gate delays) generates noise pulses that look,
roughly, something like this:
. _ _
.N1 ____| |_______________________| |_________________
. _ _
.N2 ________| |_______________________| |_____________
. _ _
.N3 _____________| |_______________________| |_________
. _ _
.N4 _________________| |_______________________| |_____
. _ _ _ _
.CLK ________| |_________| |___________| |_________| |_
with the result that your circuit (assuming edge rates equal to
those of the comparator) is generating five times as much noise as
the output of the comparator, FIN.
Do you know how much logic is on your PCs motherboard? Or in your
keyboard, or your mouse? Do you think the designers avoided adding 4
gates because they would make "hash"?
When you design logic, do you actually avoid running signals through
gates because gates cause emi?
I offered a circuit that has two cans and does everything the OP
specified, and is timing-hazard free. And you're complaining that I'm
using a quad xor gate to process his signal, and that's bad because
it's an emi hazard. Preposterous.
John
