Hi Guys!
I bought a solar panel which is producing 22v (Open circuit) and 6Amps (Short Circuit). These are the results at 11:15am.
Basically I want to use following to appliances directly with the solar panel (without charge controller and battery):
1. 12v 4Amp DC Motor
2. 12v 1Amp Water Pump
Please suggest me how can I reduce voltage from solar panel with minimum possible loss of amps.
I also thought of connecting one 6v bulb in series and both 12v appliances in parallel. Is it a good idea?
I would be grateful if someone can share simplest circuit for doing so. (I want 5~6Amps with 12v(on load).
