Here is how I would proceed:
First, get a new DC-DC converter board, the one you have is most likely damaged.
Use a 12V bench supply that can supply plenty of current and measure the current drawn by the motor at 12V. Is this withing the range of output currents your DC-DC converter can handle? If not, then you need a different one.
Assuming the current draw was good, connect a 12V light bulb that draws about 1A to the output of the board, set the output voltage all the way down. Connect your 4.8V battery. Measure the voltage across the bulb and adjust the converter until it measures 12V.
Now connect up your motor, it should run correctly.
Bob
Bob
