I finally understood things and how they go around previously but I thank you for this information so far.
The one thing I think about so far is the 3rd point: "When you increase the voltage, the current has to decrease because the product of the two (which is the power) must remain the same -- you cannot create power. And you always lose some power based on the efficiency of the converter."
Could you clarify this more? I know im working on DC circuits and batteries but what I wonder about the most is: I heard in AC circuits and transformers its possible to increase the voltage and the amperage is that correct?
No, its still applies as Bob said.
eg. your transformer has 120VAC(240VAC depending on your country) going in
depending on the ratings of the transformer it can transfer xx Watts of power. If you are stepping the voltage down to say 12VAC on the secondary then you have that XX Watts in power available minus losses in the transformer. Without going into indepth transformer theory, you can google that. lets say you can produce 50W of power on the secondary so 50W / 12V = 4.16Amps. If you want more current out of that transformer you could rewind the secondary with heavier gauge wire, but since there are less turns of wire cuz of its additional thickness there's going to be less voltage induced into those windings. so you may increase to 8 amps but you are not going to have 12VAC any more ....
50W / 8A = 6.25VAC. You can see from the 2 examples, I doubled the current and halved the voltage.
Its still the same pricnipal of you go the other way. You step up from 120V AC input to 1000VAC (1kV) output. The transformer needs much more windings on it to induce that higher voltage, the thickness of the wire is going to be very fine and hence very little current capacity. Lets still work with our 50W capacity of the transformer
50W / 1000V = 0.05Amp
you CANNOT increase current without decreasing voltage
you CANNOT increase voltage without decreasing current
The Volts x Amp must = Watts
And when you say " the current has to decrease because the product of the two (which is the power) must remain the same"
Im not creating power but rather using power from the batteries that were conserved.
If it is possible to converter batteries from DC > AC then tamper with the power output.
Please clarify that point more and I thank you all so far for the help and support.
The batteries are capable of a given current out at a given voltage. That = a given power in Watts available to do work. You CANNOT change it
Dave
