Bill said:
De-ionised water would work. I've seen that used to cool the floating
anode of an X-ray tube running at that kind of voltage. It's got a
higher heat capacity and a lower viscosity than most oils.
An alternative would be a heat-pipe, if you could guarantee that the
fluid being evaporated could be spread evenly over all your zeners.
Plugging them all into a block of a alumia - which does have a
respectable thermal conductivity - 29 W/m/K - could work. Aluminium is
better - at 201 - as is copper at 385 but both conduct. Diamond is
brilliant (pun intended) at 900, and it is a good insulator - a vapour-
deposited layer might be worth the trouble and expense if you were
really pushing the state of the art.
What i did (before test of PCB) is use 0.020 Getek, did a "pour"
around each part for a heatsink, and a rectangle on the back as added
heatsink.
Each PCB has 168 zeners, a test at 1.4mA (about 25W) yields about
150mW/zener which has a max rating of 225mw "On FR - 5 board using
recommended solder pad layout"; the PDF showing _only_ pads for the SOT-23.
At a max 1mA use, i have a lot of elbowroom if i had used their
"layout"; so i am guessing at least a factor of two for "still" air.
I thought of water, but it is too easily contaminated with ions to
make it practical except for use in a controlled lab-type environment.
This project is for hobby use; re-build Victoreen Corotron(TM) HV
regulators used in some TVs,so cost is a definite factor.
