Robert Baer
I would like maximum thermal transfer (due to thermal circulation in
an enclosed tube) as well as good electrical insulation to (say) 25KV
minimum.
The tube is 1.5" diameter OD by about 6" long.
Two PCBs will be stacked end-to-end, and centrally located; their
dimension is 1.17 wide by 2.850 tall.
There are 168 zeners on each board for about 25KV zener regulation;
at 1mA this would dissipate 25 watts (this is near max of guesstimate use).
Would the Cargill FR3 transformer oil be the best
(www.cargill.com/fr3fluid/) to use; better than mineral oil-based
transformer oils made from either naphtha or paraffin?
All comments and suggestions are appreciated.
minimum.
