Hi again, all. I am trying to source a component I am having a hard time finding the exact numbers/letters on the available replacements. I think I may have found what I believe is the closest one. Can someone take a look at the information I have provided and let me know if I'm close please. This is still a part of another thread, however, I didn't want everyone to get bored reading through it and this one as well. So here goes:
The component I am trying to replace is some sort of power supply chip for other components in a Automotive Delco Radio System containing three components. The Control Head (CH) with the buttons. The Control Data Module (CDM, the central brains of the system) and a cassette/EQ component. The CH and the Cassette/EQ portions plug into the CDM. They derive their power supply from the CDM. The component I am trying to source is most likely the component that sends the power to the peripheral components.
I have two of these systems, with one working. The reason I am confident this component is faulty is because they do not test out the same using a multimeter on the pins of the component. The good one shows differing values with the multi-meter in diode function, while the bad one is not showing anything on several of the pins doing the same test. So my goal is to find a working comparable component.
The bad one has these letters/numbers on it: Top: 014, Middle: M34AK, Bottom: 44222. The good one has these letters/numbers on it: Top: Delco 16144222, Bottom: L88HA344. They are both exactly the same size and are on exactly the same model PCB's and in the same places. I think the numbers on the first one (the bad one) was a derivative of the second component's numbers, since there are several that are very similar: "44222" and "16144222"
I have found the second component (Delco 16144222) after doing a search, however, when I try the PDF for the datasheet, it does not come up. https://www.jotrin.com/product/parts/16144222
I have found the description somewhere else (?) of it as being a "solenoid driver." The first one (M34AK) I cannot find at all.
I then found something very similar with "L88HA" on it, which is a partial number of the second good component, on Ebay. You can see it here: https://www.ebay.com/itm/282717856409
It shows up as an L2750 "Dual Low Drop High Power Operational Amplifier. I found the datasheet for it: https://pdf1.alldatasheet.net/datasheet-pdf/view/22428/STMICROELECTRONICS/L2750.html
This component seems to be available and appears to be the very same in size. Because I don't know exactly what each pin does, I don't know what I am looking for. The "tab" pin and the number 6 pin are connected. I do know that and mine are the same. I'm sure that is probably common for this style component though.
I'm not used to comparing datasheets to applications, so my question is, would the L2750 (L88HA) be the probable replacement component for what I am looking for, which is some kind of power supply for the peripheral components? Most of my confusion comes from the differing descriptions of the components, IE., "Operational Amplifier" and "Solenoid Driver."
I've attached photos of the front and back of the PCB, the component location, and the board with the bad component on it. The good unit is the very same, as far as the boards and the component locations.
Thanks in advance for any help.
