capacitor
bertus
Hello
The picture has a lot of grain
The picture does not show any numbers
Are those on the other side ?
Bertus
hi all just for info it the violet or purple on top ang grey at the bottom , thanks again ,i cannot make out the numbers
thanks very much to all
For each of the capacitors pictured, there will be a wide range of capacitance values produced in each package.
If you look at
https://www.reichelt.com/at/en/ceramic-capacitors-egpu-c3169.html?&nbc=1
The page up from your link you will see that the pictures for more than one value ar identical.
Noteably, the 1nF and 1pF use the same image. These are a factor of 1,000 different.
Ideally, you would determine which value you need, from markings or circuit schematic and replace with a like value.
