I believe I need a replacement cap for my lathe, problem is I am not too tech in the electric motor arena so I have a job explaining exactly what I need. I'd be grateful if someone could point me in the right direction if I explain what has happened and what I have gleaned so far. Originally I believe I overloaded the motor a couple of times when the gear train had seized which resulted in the motor only running slowly since. I am not sure if it is 'run' or start and run but when I tested it the needle on the multitester went up and stayed there instead of returning to zero which means that it is faulty but I am not sure if it means that the 'run' part is the fault alone, as I say, I don't know the exact nature of the required capacitor. The motor is made by Brook motors, model Gryphon, single phase , cont rating. Thanks in anticipation David.
Platforms
Content
