Can 2.5V to light up a typical 3mm LED?
Jasen Betts
I acknowledge the safety measure, but is the threat real?
Not with ordinary resin encapsulated thru-hole LEDs. the die bonding
tends to fail before thermal runaway can transform the die into a
bulk resistor
rectifier diodes have stronger bonding and do often fail shorted.
Mr. Man-wai Chang
bulk resistor
So I should not expect a diode to behave like a fuse or a resistor? OK....
Let's just talk about average LED. I don't need rectifier for the
meantime...
@~@ Remain silent. Nothing from soldiers and magicians is real!
/ v \ Simplicity is Beauty!
/( _ )\ May the Force and farces be with you!
^ ^ (x86_64 Ubuntu 9.10) Linux 2.6.39.3
ä¸å€Ÿè²¸! ä¸è©é¨™! 䏿´äº¤! 䏿‰“交! 䏿‰“劫! ä¸è‡ªæ®º! è«‹è€ƒæ…®ç¶œæ´ (CSSA):
http://www.swd.gov.hk/tc/index/site_pubsvc/page_socsecu/sub_addressesa
Mr. Man-wai Chang
In professional applications, you'll also need to consider the power
dissipation, but that's another few pages of discussion ;-)
Talking about the wattage over the current-limiting resistor?
http://www.elmassian.com/trains/dcc-battery-rc-electronics/misc-electronics/led-lighting-basics
/ v \ Simplicity is Beauty! May the Force and farces be with you!
/( _ )\ (Fedora 18 i686) Linux 3.9.6-200.fc18.i686
^ ^ 20:27:01 up 17:16 0 users load average: 0.03 0.02 0.05
