Wiebe Cazemier
Probably for no other reason than there being a 'spare' pin. If they read
zero to one another, then it's pretty safe to assume that they are both
connected to the same place. Can you not find a data sheet for the tube on
the 'net somewhere, or a schematic for the whole monitor ?
www.eserviceinfo.com might be a good place to look for one.
I can't seem to find one. But I think it is indeed just a spare pin, especially
because the neck board also connects them together.
As far as your
calibration fears go, I would suggest that when these shorts are removed, it
is going to want a good set-up anyway ...
What I meant was, that most repair guys aren't really interested in delivering
a perfect monitor. They just want their paycheck and be done with it. I have
experience with the repair service in question (the only company in The
Netherlands that is authorized by Eizo), and I know what shabby calibration
they can do. On the other hand, I can't do any at all (the correct way), so
for that matter...
BTW, I found something on impregnated cathodes, which is what Sony Trinitron
tubes use:
Impregnated cathodes are much more robust. They can be applied at a higher
cutoff voltage and thus deliver a smaller spot without premature wear. They are
more sensitive to a too high heater temperature, however, because they are
operated at a higher temperature to begin with. They do evaporate more metal
during their lifetime. At one time there was fear that they would deposit too
much metal on the glass around the electrodes, leading to leakage currents.
These can cause drift of focus and screen voltages and can disturb the cutoff
current measurement. Those can influence the picture too.
I guess this depositing is what's been happenning. Can someone tell me if the
cap-discharge method, or professional rejuvenation, is perhaps particularly
dangerous? (just trying to rule out damaging this monitor...)
