Please elaborate on that. I can understand that a multiplying A/D might be
linear enough at low levels to produce an output that could be integrated
over time to give a better accuracy than 1 LSB, but a system that uses
digital processing for both current and voltage needs more bits to produce
a meaningful output. This is even more so for complex waveforms, or where
the voltage is AC and the current is DC. But the main practical limiting
factors at low levels are nonlinearity, phase shift, distortion, and
offset, especially in the current measuring components.
Paul
Sample the voltage and current waveforms with, say, an 8 or 10-bit
ADC, preferably simultaneously, but at least not many microseconds
apart. The voltage waveform is usually pretty constant in amplitude in
regular AC systems, so adc resolution is not a problem there. The
current waveform can have a huge dynamic range, 10,000:1 or so for a
metering-quality measurement. So add a few lsb's of noise to the
current signal before digitizing it; that smears out the quantization
errors. Now software autozero the current samples to take out any dc
offsets, to a fraction of an lsb, say, 16 bits or so. Now multiply the
zeroed current sample with the paired voltage sample and average the
product points to get power, integrate to get energy. The statistics
are great if you do the math properly. A few watts resolution out of,
say, 20 kw full-scale is possible.
Actually, DC offset in the current signal washes out when it's
multiplied by the voltage sine wave samples and averaged to make
power, as long as the voltage signals doesn't have offset too.
Software autozering both the voltage and current data allow you to use
unipolar, unsigned adc's and not wory about residual (or huge) dc
offsets in the signal conditioning or the adc itself.
The worst low-power error will be crosstalk between the voltage and
current signals, which can happen magnetically, or in the adc mux, or
any number of other interesting places. Any crosstalk or correlated
noise does produce a power offset, some of which can be software
fudged out.
John
