The Phantom said:
As measured with true RMS meters, right?
If watts are higher than VA, the power factor is greater than 1, since
power
factor is defined as watts/VA.
According to
http://en.wikipedia.org/wiki/Power_factor, power factor is
never
greater than 1.
Can you give a specific example of non-sinusoidal waveforms where the
power
factor would be greater than 1?
If you measure the voltage and current with a true-RMS (AC+DC) meter, I
don't think there is any condition where true power is greater than
apparent power. But if you use other types of meters, particularly with
capacitive coupling which removes the DC component, there might be such
effect.
Whenever there is asymmetrical distortion on a sine wave, phase angle
cannot be measured accurately, or in other words, it becomes undefined.
Most phase angle meters use zero crossings to determine the measurement
points, and thus a waveform with zero crossings not exactly spaced at 180
degrees will read differently when the polarity is reversed. Also when
there is crossover distortion, such that there is a flat spot at the zero
crossing, a phase angle meter cannot determine the point accurately.
Power can be measured accurately by using an analog multiplier circuit,
such as the AD534. I used this IC to design a DC wattmeter, which can also
be used on AC and distorted waveforms. The main problem was isolation from
the shunt that was used to measure current. A Hall effect sensor could have
been used, but an isolation amplifier did the trick.
You can also measure power using A/D techniques, especially if you use
simultaneous sampling converters. You must perform instantaneous products
of current and voltage, and then take an average of these sums for true
power.
Measuring power in three phase systems, especially with unbalanced and
non-linear loads, is even more complex. It is not so difficult in
star-connected systems where you can measure each leg and the voltages to
neutral, but a greater challenge in delta systems.
Paul
