North
This is just plain stupid. The number one reason why you should never
heat a house with a stove or oven is grease that gets trapped in all
the little knooks and crannies in the stove. When that shit catches
fire, its all over unless you have a good chemical fire extinglisher.
Get sued by the power Co., go to prison, get fucked in the ass, ect...
Famous last words "I WON'T forget"
As long as you are vigilant about making sure the main is off, you
won't backfeed the grid, however there are other reasons why you do
not want to hook a POS generac 5kw genset to a 20Y/O panel.
Ive seen breakers stick "closed" especially mains, IOWs they are on
when you think they are off.
The main reason why I wouldnt do it the way you suggest is this:
I too have a 5kw generac, its kinda old but still works. I use it at
my cabin and sometimes on jobs (I have a real standby genny at my
house) Sometimes the genset will rev-up all by itself, many things can
cause this from bad fuel to dirt to murphy, when this happens, the gen
will surge HV (NEVER COUNT ON LOAD CONTROLLERS). One day the genset
went haywire and sent a 600-2500VAC surge for 5 whole minutes to my TV
killing it in a firery/smokey death, if I had this thing plugged into
the house panel, who knows what it would have destroyed.
For a POS genet such as the 5kw generac, I would only use outdoor
extension cords and power strips with surge protection. Just because
the genset only has 2 110 outlets does not mean you can only run two
things at a time, it just cost less for them to build it that way and
the generac was built for industial use in which most applances
(tools) run off of 220 anyways. I do understand that you need to run
the heatpump or whatever that requires 220, but I would wire the
heatpump straight to the genset (via extension cord as you described),
not through the panel.
Look at it this way; say you do what you say you want to do (genset to
panel with NO tranfer switch) and somehow the genny fucks-up and your
house burns down. Do you think that you home-owners insurance will pay
when the fire dept tells them that your genny was improperly/illegally
installed ?
The tranfer switch not only protects against backfeeding but also
protects from voltage spikes and surges common with an old generator.
Running extension cords and pwer strips is rather safe, it you have a
voltage spike the surge protectors in the power strips will trip. Sure
its a hassle to drag out the cords and all, but laziness is not a wise
survival or survivalist choice, YMMV.
A manual transfer swith from HD is rather cheap, have you looked into
one of these ? they are easy to install and if you are the homeowner
you can legally DIY, YMMV.
BTW the power Co will be far more pissed about the lack of a tranfer
switch then a pulled meter, in fact, if they happen to find out, they
may just pull the meter and not replace it untill after you pay the
$10,000 fine (yes thats ten with three zeros)
From this statment you need to STOP NOW and read up on basic AC wiring
and home electrical systems before you kill yourself !!
n.
installed ?
PS: What about grounding? I believe OSHA regulations require the
generator (manufacturers) to have its own grounding system (being
grounded to the chasis inmost cases). So by backfeeding into the house
system, what safety procedures should I take to ensure a proper/safe
ground?
TIA
Friday
n.
