Hi guys, im new here so please bear with me.
I have an old black & decker HD1245 bench grinder that has been a great little servant to me over the years. Recently it has stopped spinning but still hums (it does spin a little but with no force), i can spin it manually and it'll turn on its own, but it doesnt pick up any speed. After doing some reading on the subject, I believe the capacitor may be faulty and will try to switch it out first, problem is.. i don't know which one or where to get it. I don't know if its a run cap, a start cap, or both - or even if that's relevent anymore.
The capacitor says:
DALY
124-138 uf
110V RMS
MSDA J4 18S
RB
UK MADE
I cant find anything relating to it on google, but if i can match the figures as best i can, it should be alright - there must be a modern equivalent for it, i assume as long as im within certain ranges (even higher in some cases), it could even be a good upgrade. I jusr can't identiy it, and am not up with these things, so can't source a replacement. I really don't want to put the wrong part in it.
Any help would be greatly appreciated
Here are the grinder specs if that helps:
Black & Decker HD1245 6" (150mm) Heavy Duty grinder
240V
1 ph
3000 / min
2.8A
380W
Type H2
Capacitor and id plate pics attached
The capacitor says:
DALY
124-138 uf
110V RMS
MSDA J4 18S
RB
UK MADE
240V
1 ph
3000 / min
2.8A
380W
Type H2
