"Glenn Myers" wrote in message
This is just an experiment Jim, not a military contract
I'll
settle for anyone's best guess ... expect mine.
If it's just an experiment, then you can just give it a try. You probably
won't damage anything, and if you do, and you have a bunch of these surplus,
it's no big deal. But as Jim points out, you should have some idea of what
you are trying to do, and for modulation up to 60 Hz into a resistor it
should work just fine. But a solenoid may be a different animal, and you
have to provide some way to deal with the inductive "kick" when the supply
is going low. A diode across the coil will probably be all that is needed.
But it is still a mystery what you have in mind.
If you really want a power amplifier or a function generator, then there are
some very inexpensive ICs that can do what you want MUCH better than the
723. It's been so long since I've used one I forgot they even existed. Even
for power supplies, ICs like the LM317 or LM2931 are much better and cheaper
(like 25 cents) and require less external components. And for about a dollar
you can get a 4 watt stereo amplifier TEA2025 in a DIP package:
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000172.pdf
I know it is tempting to use parts you already have to build something, but
usually it is better (and cheaper) to get a more modern part that does
exactly what you want. And it's also futile to imagine possible alternate
uses for parts you have. I have thousands of surplus parts that are now so
old that they are obsolete, or damaged because of humid storage conditions.
I hate to throw them away, but I've had them for 20 years and I've only uses
a few of them and I've sold a few, and it really cost me more in time and
effort than I got from the sales.
If you want some parts really cheap, they are listed at:
http://www.pstech-inc.com/surplus.htm
and an even more complete listing at:
http://www.pstech-inc.com/PARTS.txt or
http://www.pstech-inc.com/PARTS.xls
No guarantees on what I actually have or what condition, but I'd be happy to
find good homes for not much more than shipping costs from 21030.
Paul
