amplify 40kHz audio signal using TL082: first two stages are fine, but high noise from the third sta
F
Fred Bartoli
lemonjuice said:
As someone already mentioned its normal the more stages you add the
more noise you get. More current noise from bias currents into the
opamp flowing into the output resistors, voltage noise in the devices
in the opamp etc... . Each of these noise contributions gets amplified
in each successive stage and the noise sum also gets added on until
your circuit starts giving off false alarms.
Nope. Only the first stage matters, unless the design is completely screwed
(which it isn't).
Your other question was how to improve the 3rd stage. How well are
your resistors scaled against noise? Plug into the total rms output
noise formulae the values for the corner frequency for voltage
noise(from opamp datasheet) , corner frequency for current noise , the
feedback factor, corner frequency for the closed loop gain function,
plus the thermal noise resistor values. Calculate each noise component.
if the resistor noise component is much greater then the other 2 then
you need to scale your resistences. a rule of the thumb used for low
noise design is
Eno(V)^2 + Eni(I)^2 = 1/5*Eni(thermal)^2 I'm sure you can find these
formulae on the web or in an electronics book. In case you can't let
me know and I'll try and dig them up. It also helps looking at them
too because you'll know what is actually increasing your noise and what
to look for in a low noise Opamp.
Competing for an LB award from FB?
L
lemonjuice
(which it isn't).
Really! So the noise contributions miraculously disappear from the the
output of the first opamp! Damn what an amplifier that is. Tell me more
as I won't go into explaining why and how the first stage affects
noise.
Sorry if I'm too advanced man... its basic electronics.
Joerg
Hello Ken,
I hadn't thought of using an LC circuit for this case. At 40KHz it may
not be such abad idea.
An LC would be pretty easy at 40kHz. However, it depends on what the OP
wants to do. If he intends to do pulse echo with good range resolution
it needs to stay wideband.
Regards, Joerg
L
Larry Brasfield
A correction, motivated by one of Fred's rare
technical efforts apparent in this thread, is inserted
below. The OP should take note of this. I have
added a few other details and notes as well.
There is also a little humor for those who do not
take themselves way too seriously. (See "1.")
The need for this correction underscores the
importance of peer review and the value of
stating assumptions and showing enough of
the analysis to permit it to be critiqued.
[Frequency response revised and moved.]
It has come to my attention that the 3 stages are not
"like" as I had stated. The last stage has about 7.16
fewer dB of gain than derived in my pre-corrected
analysis. Also, due to the improved loop gain in the
last stage, (as compared to that earlier analysis), the
-3dB bandwidth is about 59 KHz (rather than the
49 KHz mentioned before), and well centered on the
OP's 40 KHz signal. These corrections affect the
amount of noise that should be expected at the final
stage output, as detailed below.
The bandwidths will change with a transducer in
place, due to the slightly higher loop gain that will
produce in the first stage, so it would be premature
to worry about noise bandwidth just now.
[The input noise still appears to be correct.]
If you were to short the input, then, due to the
thermal noise of the input resistor, you would
have an equivalent input noise density of about
sqrt(4 k T R) = sqrt(4 * 1.38e-23 * 300 * 1e4)
or 12.9 nV/sqrt(Hz). Adding to that the input
voltage noise of your op-amp, 16 nV/sqrt(Hz)
typically, (and adding RSS-wise), you should
expect input noise of about 20.5 nV/sqrt(Hz).
If we were going for accuracy, a smidgen could
be added from the feedback resistor, but its
contribution would be lost in the errors already
in this calculation. (Fred might be willing to
enumerate or even quantify them for you.)
[Cut incorrect gain figures and calculation.]
With the OP's stated 200K feedback R (not the
"like" 500K I mistakenly assumed), the gain is
closer to 90 dB. This results from the ideal gain
of about 94 dB (= dB(50 * 50 * 20)) with losses
of .63 dB per stage for the HPF's, .97 dB for the
first 2 stages due to their (low) loop gains of 2,
and .17 dB for the last stage with its loop gain of 5.
The output noise density is then
20.5 nV/sqrt(Hz) * 10^(90.0/20) V/V
= 648 uV/sqrt(KHz)
Multiplying by the square root of bandwidth yields
an expectable RMS output noise of 157 mV.
[Noise bandwidth adjustment unmentioned.]
With your transducer as the input, the noise
could go up or down depending on its source
impedance. That is why you would have to
measure it or take it off the datasheet to see
whether the noise you see with it connected
is what it should be.
Once the input is better characterized, it
will probably be easy to revise the first
stage a little bit to get lower noise.
I would bet good money on long odds that
the first stage can be revised to bring the
SNR up by several dB, once the input is
better known.
[corrected in place:]
As for why you do not see the noise on the
earlier stages, that would depend on your
instrument. With a typical o'scope, not being
able to see the few mV to be expected at the
2nd stage output is to be expected. And of
course, it's even harder at the 1st stage.
The comparisons suggested between the noise
to be expected and the noise you see should
be used only for limited purposes, such as
deciding to proceed further along the noise
investigation rather than looking for another
source for the noise. [1] The way to finally
evaluate noise should involve the measured
gain of the amplifier, not its nominal gain.
[1. For example, suppose you had left an
op-amp unconnected whose inputs just so
happened to float together, and stay within
about 15 uV of each other, (offset by Vos),
such that the output was miraculously active
for an observable length of time during the
few 100's of mS before they both float to the
rail, and if that op-amp was paired with the
first stage, then, if you looked at the noise
appearing on the final stage quickly enough,
(within say, 200 mS and allowing some time
for noise observation averaging), you might
see several millionths of a dB of extra noise
that: arises at the open input at the about the
same level as the other stages have (which
estimation includes input current noise); then
appears at the output of that unconnected
amplifier after a gain of about 40 dB; couples
into the input thru the typical 90 dB of channel
isolation; and competes (at -45 dB relative to
the *real* noise sources) for a position as the
top dog noise source. This would seem to be
far-fetched in the cold light of day, but late at
night, when demons are at play, who knows
what can *might* [2] happen? ]
[2. Here, "might" must be distinguished from the
false certainty that plagues us all from time to
time, some more and more often than others. ]
If you peruse the rest of this thread, (with
filters in place, I advise), you will find some
comments about your op-amp choice that
you may find useful. And if you care about
input noise and power consumption, take
suggestions about using CMOS gates as
amplifiers with a degree of skepticism.
I have no idea what that is. Since, (apparently),
you are reaching into the noise floor for signal,
it may be worth your while to post the detector
and solicit ideas for improving it.
It is also worth noting that the above analysis
predicts the RMS value of a random signal with
a Gaussian amplitude distribution. It is common
to figure on seeing 5 times more peak value, but
if you want to calculate the actual rate at which
your detector will false detect due to that noise,
you need a more sophisticated approach based
on the Gaussian statistics.
A tighter
bandpass filter could do some good as well.
A good place for that filter would be after the
first stage. If you use an active filter, that will
be a necessity. If you use an LC filter, that will
be prudent due to coupling considerations and
noise performance issues.
P.S. to Fred: If you reply, please try to take a
rational approach to this, or, failing that, come
up with some new names and more imaginative
invective. Your latest efforts have become so
repetitious that they are really quite boring.
L
Larry Brasfield
Mainly just laughs here.
Fred Bloggs said:
Larry Brasfield wrote: [snip]
No one is reading your sh_t any more. Quite telling that you have no clue how much of hot air bag you sound/ and appear.
Thanks, Fred. I appreciate that. When my style
begins to please you, then I will start worrying.
[More typical FB crap cut.]
Not to worry- hard to imagine anyone with so much time on their hands that they waste it reading your trash.
So, I take it you have no way to substantiate.
Just as I thought. You are a nasty fabulist.
All you have done is make some simple 4KTRB and BW estimates- and then stopped as usual.
I went as far as was needed to explain the reported
observation that brought the OP here. Going beyond
simple would be a disservice at this point, for reasons
you could figure out yourself if you thought about the
OP's situation rather than your own aggrandizement.
This is a good example of your propensity to blather some elementary factoid trash and then make no sense of it.
I note that you have failed to show any particular
way in which my analysis does not make sense.
Telling. Whenever you are shown up, out comes
a load of crap. Who do you imagine is fooled?
The only problem with my analysis is that it
explains all the OP's reported facts, relying
only on well settled and accepted theory
together with facts that were either posted
by the OP or are publicly available (except
for one [1]), *and* was not contemplated
by Fred, the master of all things electronic.
Really? The OP builds a chain with 115 dB gain and all you know how to do is elementary electronic input noise- pathetic really.
More baseless assumption and conjecture.
What real reason is there to believe that I
could not have completed a full noise
analsysis? (Try not to confuse your need
to denigrate with "real" here, Fred.)
You have done no analysis worth noting as usual.
Translation: Fred cannot rationally refute.
How many times do you need to get your ass kicked
If you are the ass kicker, and my unblemished ass has
been the target, then your counting skills are bad.
before you realize you're less than third rate garbage- so far *all* of your product has been laughably weak, inaccurate, and
worthless.
So you like to believe. What does it do for you?
Couldn't get into the program?
I'm still not sure what program you refer to, but I
never took any courses aimed at tecnicians, nor
did I try to get into any such program. That you
are able to conjecture that way is pathetic.
Guess your obsession with reading comic books just wasn't enough preparation- ahhh- too bad.
More fabulizing. Your percentages are getting
very bad, Fred. Maybe it's time to check your
assumptions. They are not working.
[More of the same cut for space.]
[Fred's venture into psychoanalysis cut.]
[More of the usual name-calling cut as redundant.]
go back to your messy hovel of a cubicle and drink your soda...
I wonder how long it will take you to figure out
that I will never take orders from you. That it
has not yet occurred is quite telling.
F
Fred Bartoli
"lemonjuice" <[email protected]> a écrit dans le message de
noise.
OK, so you're saying that the second and third stages noise matters.
Well, lets do the really, hem..., advanced maths for you...
Have 3 identical stages with input referred noise en and gain G.
The total output noise is :
sqrt(G^2(en^2+G^2(en^2+G^2 en^2)))= en sqrt(G^2 + G^4 + G^6)
the first term being the output stage contribution, the second one the
second stage contribution and the 3rd one the first stage contribution.
OK?
Now, you build an amplifier, isn't it? So G>1. You pay attention to
amplifier noise so your signal is low level too. Thus you want your gain
above few units. Say G=3. (note the OP wants its gain = 50)
Onoise = en sqrt(9+81+729) = 28.62 en
Now, I magically make the output noise disappear, as you say so well.
Onoise = en sqrt(81+729) = 28.46 en
Even better now: I magically make the second stage noise disappear
Onoise = en sqrt(729) = 27 en
Wow, that's an 'enormous' difference.
Now, let G = 50, as is the case here, redo the computations, and you, the
amplifier noise expert, enlighten us about the _huge_ 3rd stage noise
contribution.
Yeah, obviously look at the 3rd stage noise.
I agree on this, guy. This is really basic electronics, but this is still
too advanced for you, like it seems some 1.35V low voltage voltage
amplifiers.
You appear to be a bit out of juice, lemonhead.
L
Larry Brasfield
An almost purely technical post, after severe editing.
Fred Bloggs said:
Larry Brasfield wrote: [SNIP]
the
OP has asked about a final stage in an amplifier
chain with enough gain to make its input noise
visible on an oscilloscope, wondering why it is
"significantly corrupted by noise". Fred is now
upset because I have explained it (or pretended
to explain it in his delusional perspective) when
his own far-fetched diagnosis has fallen flat.
[snip]
What other noise analysis do you believe is
relevant to what the OP reports seeing?
Have you ever actually done any practical
noise analysis, such that you can explain
why "All you have done ..." should perhaps
be considered the insult you surely intended
rather than a comical and telling snipe?
(And before you reply, you may want to
consider Fred Bartoli's post of 12:16 today
where he makes a point relevant to your
"snipe". He appears to know more about
real noise analysis than you do.)
[invective gone]
I am unable to replicate your 115 dB figure.
In fact, I believe it to be erroneous. Do you
have any way to show how you arrived at
it, or was it too ephemeral to permit that?
In other words, either prove it or make clear
that it was one of your thin air productions.
[SNIP]
F
Fred Bartoli
Well, I won't be so sure...
L
lemonjuice
amplifiers.
LOL . Youu should stop hoping that I'd answer a delinquent like a
Bartholi!
John Woodgate
I read in sci.electronics.design that Larry Brasfield <donotspam_larry_b
[email protected]> wrote (in <W%[email protected]>) about
'amplify 40kHz audio signal using TL082: first two stages are fine, but
high noise from the third stage', on Fri, 18 Mar 2005:
I get 94 dB voltage gain from the OP's 50 x 50 x 20. Anything more
complex makes my brain 'urt.
Am I turning into an analogue Genome?
John Woodgate
I read in sci.electronics.design that Fred Bartoli <fred._canxxxel_this_
bartoli@RemoveThatAlso_free.fr_AndThisToo> wrote (in <423b398b$0$22858$6
[email protected]>) about 'amplify 40kHz audio signal using TL082:
first two stages are fine, but high noise from the third stage', on Fri,
18 Mar 2005:
Only in France and Wales.
L
lemonjuice
"snipe".
I checked it. All wrong.
L
Larry Brasfield
Not all wrong at all. His fundamental point, which
you would do well to learn, is that the noise output
of cascaded amplifiers with moderate gain will be
dominated by the input noise of the first stage.
This principle, (in a more general form that applies
to any set of gains), is known as the "Friis formula"
or "Friis noise equation". I suggest you look it up,
study a bit, then extend an apology to Mr. Bartoli.
F
Fred Bloggs
[...snip drivel...]
As usual we all see you doing a bunch of pussy factoid arithmetic, but
what have you accomplished? You have hit a brick wall- absolutely no
plan whatsoever to define or fix the noise induced threshold crossing
problem. And that's because you don't know how...
F
Fred Bloggs
Nah- you went as far as you could- and that wasn't to far...
Going beyond
Yeah- right- bullsh_t.
[...snip drivel from a drowning rodent...]
F
Fred Bloggs
I am not here to educate you...
[...snip drivel from drowning rodent...]
F
Fred Bartoli
18 Mar 2005:
Sorry John, but I miss the point.
Probably some more shade in my knowledge of english.
John Woodgate
bartoli@RemoveThatAlso_free.fr_AndThisToo> wrote (in <423c21a6$0$22865$6
first two stages are fine, but high noise from the third stage', on Sat,
19 Mar 2005:
The appended 'isn't it' is characteristic of French ('n'est-ce pas?')
and Welsh English (not Welsh Welsh) spoken language. Note that the 'it'
in 'isn't it' has no referent in the preceding sentence, as in 'He's a
really tall man, isn't it?'
L
Larry Brasfield
This has been converted, via a process I will call the DERF transform [1].
This elision process conforms to accepted Usenet quoting practise with
the exception that elided text is replaced by "[DERF]" and, where needed
for grammaticality, short sequences with a '[]' pair are inserted.
[1. Application of a filter removing Dreck, Extraneousness, Redundancy, Foolishness.]
Clever, Fred. Assuming you meant "too far", you seem
to have understood my earlier made point that complicating
the analysis beyond what significantly affects the result is
a disservice to the OP. I do try to avoid "too far".
As for " went as far as could", yes, you've gotten it.
I operated within that constraint except for my analysis of
the dreaded "open JFET op-amp" effect. I hope you
were able to follow that and enjoy the chuckle I did.
(However, I doubt both clauses of that conjuction.)
Woops, I guess you were unable to understand that point.
Was there any particular part of it that you had trouble
with, or is the whole concept of engineering approximation
something you find difficult to grasp? Maybe you are
unaware of the Friis formula and its implications here.
I admit to puzzlement in light of the awe you seem to induce
in some folks here. Of course, that also puzzles me.
[DERF]
(Well, 1 down, 2 to go. I'm disappointed, having
missed that "challenge" you mentioned elsewhere.)
L
Larry Brasfield
I agree. However, your pretense that there is some
additional relevant noise analysis that you cannot
divulge for anti-educational reasons is educational
itself. Unfortunately, it's not an education I need.
[DERF]
(Well, 2 down, 1 to go. I'm disappointed, having
missed that "challenge" you mentioned elsewhere. I
guess, given your veracity, it must be coming up.)
