E
exxos
Jim Thompson said:Jim Thompson said:i would check out the circuit before cutting and adding resistors and
regulators, try to keep eveything working the way it was designed,
many
a
times i have found the 8 way connectors loose/corroded causing a no
charge
condition. just a simple back probe test to the PCM
assuming you replied to my msg, the lamp was part of those car
diagnostic
"features", I think the idea was that if the regulator shorted out it
would
light the lamp on the dash... only mine had a I/O short (at some point
in
its life) so the lamp never lite, but yet the battery was charging to to
19V... It also doubled up to raise the regulator voltage to about
13V....so
much for technology..... good idea in theory though ;-)
chris
[snip]
I think you'll find that the lamp was looking at the neutral
(mid-point of the "Y") terminal of the alternator, which is where most
idiot lights get their information... actually quite good at
indicating faults _before_ the battery goes dead.
It was in the ground, I actually grounded the point instead of going via
the
lamp, battery only got around 11V on it though at least it proved the
point.
It was actually a 12V regulator, I measued it with a DMM at the time and
even at high revs it only ever hit 12.5V, so it needed a higher ground
ref,
hence via the dash lamp. I would never have thought they would do such
tricks like that on cars, ive seen it countless times on electronics
equipment, though was supprised to see the same trick on a car.
Chris
What brand of car? Yugo ?![]()
Citroen (SP?) did well lasted a long time, have a reno now, exloded last
week, ah off topic again....
Chris
