I have a used alternator which I need to put into my car which has had a small section of the enamel (about 8mm) scratched off of one of the wires in the winding where it shows through the ventilation gaps in the case.
The alternator has been tested and is working fine.
I'm concerned the exposed section may corrode and/or cause future problems.
Could someone in the know please tell me what I should use to coat this scratched section with to protect it.
I thought maybe a spray of circuit board lacquer, but that is designed for soldering through, so will it survive on a car alternator, or maybe I need to use something more durable?
Also what is normally used by auto electricians to clean all the black muck off old used alternators without doing any harm to it?
