W
Watson A.Name - \Watt Sun, the Dark Remover\
I acquired a couple dozen Micro-Ohm 400 ohm, 0.1% resistors, and some
other values. They've probably been around a decade or more, and/or may
have been culled. In any case, I would like to check them to make sure
they're within tolerance. I thought about doing this a couple ways:
Measuere them with a Fluke 4.5 digit meter, which hasn't been cal'd in
decades, but it could give me an idea of how close they are to a common
value, even if that value isn't exactly 400.
Measure them with a Leeds Northrup Wheatstone bridge. It's been around
decades and hasn't been cal'd in a long time. But it's a bridge, so if
there is any long-term drift, the resistors should drift the same way,
assuming the resistors are all the same. My guess is they're wirewound,
which is fairly stable. But there's grunge on the switch contacts, etc.
Make a bridge out of four of the 400 ohm resistors. Again, use this to
compare them to one another, to see if they are all about the same
resistance. If I apply a few dozen volts to the bridge, I should be
able to measure a few millivolts, as long as I don't heat up the
resistors too much and cause them to drift.
One other thought. I have a precision power supply with terminals on
the back to allow me to hook up a resistance in series with the 1.000 mA
constant current source. If it is 400 ohms, then I should measure 0.400
VDc output.
I realize that 0.1% is one part in a thousand, so that's 400 + or - 0.4
ohms. That's about the residual meter lead resistance I see in my
meters. I don't have a standard resistance, traceable to the NIST or
whatever. And I don't have a friend who's working at a cal lab. So I'm
trying to make do with what limited resources I have to get the most
accurate measurement. Any helpful advice would be appreciated. Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
VDc output.
