Jim Yanik
But that realm of low forces is where grime/gummy lubricant etc
affects the feel.
you should not be making the mesaurement if the tool or workpiece is dirty.
affects the feel.
William Sommerwerck said:Tightly, of course.
There's a story that Edison asked a young man (presumably an apprentice) to
measure the volume of several light bulbs. The apprentice stated with a
ruler, a pair of calibers, trying to get precise measurements so he could
calculate the volume. When Edison saw him fussing around, he grabbed one of
the bulbs, filled it with water, and dumped into a graduate.
N_Cook said:But that realm of low forces is where grime/gummy lubricant etc affects the
feel. I would say that , on my Moore & Wright one anyway, someone has
determined that 2Kg clutch release force is about right for consistency.
Obviously fine copper wire is going to compress but it will compress
consistently, gauge for gauge, on a consistent 2 Kg force over the diameter
of the plattens. So I'd disagree with your expert.
Sometimes, when a measurement is difficult, it's time to reformulate theN_Cook said:Not the first time I've met this problem.
Say nominally about 0.05mm . With a micrometer, how much are you compressing
it? could easily be out by 20 percent out and squaring that if using weight
to length via density or resistance calculation via resistivity, is very
iffy.
If access to a microgram resolution of weighing scales then a few metres of
the wire and density of copper and allowance for enamelling , but no highly
accurate weighing machine. Optically comparing under a microscope needs
known diameter standards.
How about a longish length , folded 6 times until 64 wires. Maybe
longer/more bulk. Hand twist together until it will not sensibly tighten any
more. Take average diameter, use packing factor allowance, and infer for 1
wire diameter, how better accuracy might that be.?
If I start from known good coil of say 46swg enamelled wire and do this 64
wire trick , to work backwards, how accurate/reliable would the manufacture
sizing be ?
Any other ideas?
iffy.
sizing be ?
Any other ideas?
iffy.
sizing be ?
Any other ideas?
Make the bundle by winding the wire 32 times around two spaced pegs so
as to be certain that all the 64 wires this produces between the pegs
are parallel and not intertwined. Slip the wire off the pegs and do not
twist it, but squeeze the parallel section so that it takes up a
cylindrical shape.
Wrap another length of the same wire tightly around the outside of the
cylindrical section for a known number of turns (20 at least). Unwind
the wire and measure its length and divide by 20 to calculate the mean
circumference of one turn.
Do exactly the same thing with a length of wire whose diameter you do
know (probably something much larger, so that you can measure it
easily). You may not be able to wrap as many as 20 turns, so adjust
the divisor accordingly.
The ratio of the lengths of the one-turn circumferences will be the
square of the ratio of the wire diameters.
wire diameter,..
cylindrical shape.
Friday afternoon after a long tiring day yesterday, I cannot
thought-experiment my way into this. I'll have to have a go with some
thicker wire to start with, to work out the method you've outlined
Why not measure the resistance and calculate the diameter from that?
(Assumes the wire is just copper and is round).
N_Cook said:On Tuesday, August 4, 2009 10:38:19 AM UTC-4, N_Cook wrote: [...]
tighten any more. Take average diameter, use packing factor allowance,
and infer for 1 wire diameter,..
cylindrical shape.
tighten any
infer for 1
wire diameter,..
not
cylindrical shape.
For this very fine wire it is only ever enamelled/lacquered wire I ever
deal with, being used as magnet wire, pick-up coils and the like
iffy.
sizing be ?
Any other ideas?
Take 10 meter. Measure the resistance.
resistance is 0.0175 ohm per meter per square millimeter.
From this you can find the area.
Area is 1/4 pi d*d This will give the real copper diameter.
Two prerequisites. Pure copper and the wire is round.
