Wrong. "Interleaved" is NOT synonymous with "stacked", idiot.
You're an idiot.
and not all stacked windings are interleaved.
None are, dumbass. That's because you chose an incorrect term which
is not even used by the industry for this application.
OMG! What, no standard idiots from the retarded bandwagon response?
hence, for example, progressive- or jumble-winding. zig-zag winding is
exactly wrong for this purpose (and serves to maximise end-to-end
winding capacitance)
Philips/ferroxcube used to make a 2-part ETD29 bobbin, for much the same
reason (its not in the 2000 ed of MA02). one bobbin fit entirely inside
the other, so creepage & clearance was very high.
No. I am talking about a C I core where the primary and secondary
are separated by several inches.
Nowadays one would simply use TIW, unless its an HV transformer.
SO YES, it is the
all these types of transformers have poor coupling.
You are one of those dopes that calls zero degrees C cold.
It is all relative. Planck would have a field day with you.
I suspect your experience is limited to HV transformers, where
dielectric breakdown, corona etc considerations dominate, and you just
have to live with poor coupling.
I suspect that you make retarded assessments all the time, as you
have already made several in these few threads alone.
Try taking apart an fried, baked solid transformer from a '43
Chrysler AM tube radio apart forensically to find one mil fish paper
between 40 layers of windings of #40 wire at about 25 turns per layer,
then counting the layers to reconstruct the turns count, then
examining the primary so that you can rebuild the thing for the WWII
aviator that owns the refurbed car.
It was such a pain in the ass to re-make that I had to leave on
lamination plate out during the rebuild.. 100% vacuum impregnated
with Dolph's varnish, and baked at 425F for several hours. Radio has
worked for years since with no appreciable heat from the transformer.
I switched to #38 wire for the secondary. I suspect that made much of
the difference.
for non-HV applications, its all about maximising coupling.
Only at 60Hz. For switchers, it's all about making the circuit
perform optimally, and in such cases gaps are often needed, and very
often used to condition the drive signals.
how about this then: Assuming I can live with the resistive losses, the
amount of power I can bung thru a transformer is NOT limited by the core.
To a point. That would depend on the volts per turn used for the
design. Saturation is possible in many cases where accepted design
rules/conventions were not followed.
You still havent responded to my challenge.
Did you think it was a five minute exercise?
