w^2.M^2.(Rl+Rs)
Effective Rpri = Rp + --------------------
(Rs+Rl)^2 + (w.Ls)^2
( (w^2.M^2).Ls )
Effective Xpri = j.w.( Lp - -------------------- )
( (Rs+Rl)^2 + (w.Ls)^2 )
[/QUOTE]
It's even stranger than that. If the secondary resistance
(Rs+Rl, or just Rs if you set Rl to zero) is less than w*Ls, then
the Effective Rpri will decrease with decreases of Rs. If the
secondary resistance is greater than w*Ls, then Rpri will
*increase* with decreases of Rs.
Sorry about the delay in replying to this post, piddling
about with sums on scraps of paper. That effective Xpri
is not the leakage inductance and I can now see where the
frequency-sensitive values for Rpri and Xpri come from.
The problem starts with the fact the the only definition
of leakage inductance is based on a transformer without
any winding resistance.
Lp(leak)
| M | | | |
) ( 2 ) )|( Ratio =
Lp ) ( Ls ----> k.Lp ) )|( 2
) ( ) )|( k .Lp/Ls
The Lp-M-Ls transformer can be represented by an equivalent
circuit of an uncoupled inductor, Lp(leak), value being given
as Lp.(1-k^2), a shunt inductor of value (k^2.Lp) and a
perfect transformer with inductance ratio k^2.Lp/Ls.
The coupling, k is of course defined by k^2 = M^2/Lp.Ls.
Ok, now add the winding resistances, Rp and Rs to the
equivalent circuit and the short circuit on the secondary.
Rp Lp.(1-k^2) Rs
) )|( Ratio = |
k^2.Lp ) )|( |
) )|( k^2 .Lp/Ls |
Now transform Rs over to the primary side.
Rp Lp.(1-k^2) R= Rs.k^2.Lp/Ls
k^2.Lp ) |
Now convert the parallel L//R into the series-equivalents
to make it easy to see Effective Rpri and Lpri.
(w.k)^2.Rs.Lp.Ls
Rp Lp.(1-k^2) Ra Ra = ---------------
+--/\/\---///------/\/\---+ Rs^2 + (w.Ls)^2
La ) (w.k.Ls)^2.Lp
) La = ----------------
| Rs^2 + (w.Ls)^2
Effective Rpri = Rp + Ra.
Effective Lpri = Lp.(1-k^2) + La.
But Ra and La are both frequency sensitive.
In fact if you expand-out Ra and La in Rpri and Lpri
you get back to Wm Fraser's originals, complete with
the required minus sign in the Lpri calculation.
L1 = 12.5 mH
R1 = 32.7 ohms
L2 = 938 uH
R2 = 1.72 ohms
m = 2.8 mH
and plot the Effective Lpri vs frequency from 60 Hz to 10 kHz.
"Is this really the leakage inductance? Under what conditions
might it not be a good value for the leakage inductance?"
As above. Lp(leak) = Lp.(1-k^2), where k^2 = M^2/Lp.Ls.
The rest is a red herring, swimming up a blind alley.
